Vous n’êtes pas connecté.
I have used MountainMods earlier, but they are expensive, not very good looking, and the transport from the US easily adds over $100 to the price tag.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Railgun" (19 mars 2019, 20:19)
mardi 19 mars 2019, 20:44
Ha. Don’t I know it. But necessity is the mother of ...necessity?
For me I didn’t care about aesthetics, rather function. But of course I had many custom parts made....so yeah...it wasn’t cheap getting to the UK. But it works and will continue to work for me for years. Of course, the exchange rate was much better then.
I’ve had it for about seven years already. Doesn’t seem that long but time flies I guess.
For the record I have an Ascension.
mercredi 20 mars 2019, 13:42
I'm using a monster radiator (Mo-Ra3) and want it mounted inside the case (with pull-push),
Ce message a été modifié 6 fois. Dernière modification effectuée par "Railgun" (20 mars 2019, 13:54)
mercredi 20 mars 2019, 20:01
That's what I use, though only push. If I were to go push-pull, I'm pretty sure I'd still have room. That's odd they wouldn't help. They were more than happy to take my money.![]()
I'm using the horizon tray with a custom bracket and a custom front and back panel to specifically fit the MO-RA and some other things (140mm fan instead of 120mm for a larger HDD bracket for the rear). So to Jack's point, the mobo is facing up and the whole thing is raised towards the top of the case. They should NOT charge you any custom fees for the design of the front panel as it's already been done by me. I'd be happy to send you the files they sent if that's one of the sticking points.
My pump and res are sitting in the middle-ish underneath everything. I have two 6 XTs (as slaves didn't allow for PWM at the time) with the MO-RA up front, an Alphcool UT60 at the rear, and fans on either side and on the roof.
What mobo are you looking to put in it? I'm using the Rampage V Extreme and it fits perfectly.
These are the only pics I have handy at the moment, but hopefully it gets you an idea...these were WIP pics to be sure.
My hacked SLI bridge there too.
Undesirable
I use a Corsair 900D that gives you some bays in front. Just click the side panels off and remove the bay screws and wallah!
Way too small. I have it out in the shed somewhere. I would like a cube of some sort.
Maybe this one: Thermaltake core x71
I have it and it has enormous space and still 2 5,25" Slots - plus it has a reasonable price tag.
Reasonable price tag? WOW!
For it's design, it actually is versus competitors which could range $200+. That's in the States but if you're else where, prices can range higher.
Starting price around $700 and the first panel I wanted to change was over $150? That’s a bit on the pricy side in my book.
Ce message a été modifié 1 fois. Dernière modification effectuée par "GTXJackBauer" (26 mars 2019, 04:46)
We are talking about the TT Core X71 right?
Ce message a été modifié 1 fois. Dernière modification effectuée par "II ARROWS" (30 mars 2019, 09:48)
I have this, so no shortage of 5,25" bay...
https://www.hydra-shop.com/product/hydra-desk/
I use my PC for movie viewing, so I need at least one bay for the blu-ray player.
My real issue was the lack of good front panel USB connector, most are are too empty or just look bad with ow crowded they are.
