You are not logged in.
Saint
Source code |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 |
<UserControl
x:Name="this"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:sys="clr-namespace:System;assembly=mscorlib"
mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="300">
<Grid>
<Grid.RowDefinitions>
<RowDefinition/>
<RowDefinition/>
</Grid.RowDefinitions>
<!--Simpe databinding example-->
<!--1. set up connection for this item (ie. temperature sensor)-->
<!--2. bind values to your own usercontrol-->
<!--Binding example-->
<!--Content="{Binding ElementName=this, Path=DataContext.Value, FallbackValue=no data available}"-->
<!--default background-->
<Rectangle Grid.Row="0" Grid.RowSpan="2" Style="{StaticResource GadgetBackgroundStyle}"/>
<!--Content: binding to source value: -->
<!--Content: ElementName=this -->
<!--Content: Path=DataContext.Value, for connetion to actual connected value -->
<TextBlock
Text="{Binding ElementName=this, Path=DataContext.Value, FallbackValue=no data available}"
Grid.Row="0"
Opacity="1.0"
Height="Auto"
Width="Auto"
Foreground="#FF000000"
FontSize="15"
FontFamily="Segoe UI"
FontWeight="Normal"
Margin="0,0,0,0"
HorizontalAlignment="Center"
VerticalAlignment="Center" />
<!--Content: Path=DataContext.DataName, for connetion to actual connected value name -->
<TextBlock
Text="{Binding ElementName=this, Path=DataContext.DataName, FallbackValue=no data available}"
Grid.Row="1"
Opacity="1.0"
Height="Auto"
Width="Auto"
FontSize="15"
FontWeight="Normal"
Margin="0,0,0,0"
</Grid>
</UserControl>
Source code |
1 |
CPU 4% | 38°C | 29,3W |
This post has been edited 3 times, last edit by "Saint" (Aug 15th 2019, 8:44pm)
This post has been edited 1 times, last edit by "Taubenhaucher" (Aug 22nd 2019, 7:15pm)
warum nicht, es gibt ja auch genug vorlagen die man modifizieren kann.das bei rund 500 Leuten noch keiner die Funktion
Saint
du kannst je Element nur eine Datenquelle verbinden.
es gibt auch eine Datei mit Templaten wenn du eine vorlage importierst, da findest du auch viele Beisppiele mit individuellem XAML code.
Sonst stelle deine Frage konkreter. Was geht nicht? Hast du Dir schon mal alle vorlagen angeschaut. Da muss man auch mal ein wenig mit experimentieren. Du wirst niemand finden der dir das so macht wie du es haben willst.
Na gut, dann wollen Dich wohl alle 470 Threadanschauer dissen!?
Jetzt mal ehrlich, wie wahrscheinlich ist das
Manchmal sind die Dinge einfach wie sie sind, ohne Hintergedanken, auch wenn man es gerne anders hätte![]()
Ich hab nur gesagt das bei 500 Leuten doch sicher wer mit Ahnung dabei war aber keine Lust hatte zu Antworten.
Nur leider hab ich nur wenig Ahnung von XML ähnlichen Sprachen This post has been edited 2 times, last edit by "Saint" (Aug 23rd 2019, 1:31pm)
du kannst EINE Datenquelle pro Element verwenden.man kann aber doch sicher mehrere elemente davon in eine tabelle bekommen oder nicht ?
Saint
Source code |
1 |
DataContext.Value |
Source code |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 |
<UserControl
x:Name="this"
<Grid>
<TextBlock
Foreground="White"
FontSize="15"/>
</Grid>
</UserControl>
Saint
Source code |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 |
<?xml version="1.0" encoding="utf-8"?>
<SettingsGroup xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Name>Page</Name>
<GridSize>10</GridSize>
<Items>
<SettingsBase xsi:type="SettingsXamlItem">
<X>310</X>
<Y>210</Y>
<Height>40</Height>
<Width>90</Width>
<ZOrder>1</ZOrder>
<Opacity>1</Opacity>
<SnapToGrid>true</SnapToGrid>
<connection>service_data:1:data\sensor\aquamonitor//cpu/0/temperature/0_0</connection>
<itemType>XamlControl</itemType>
<font>
<size>22</size>
<w>Normal</w>
<st>Normal</st>
<f>Segoe UI</f>
<col>#ff000000</col>
</font>
<xamlCode><UserControl
x:Name="this"
<Grid>
<TextBlock
Foreground="White"
FontSize="15"/>
</Grid>
</UserControl></xamlCode>
</SettingsBase>
</Items>
</SettingsGroup>
Source code |
1 |
<connection>service_data:1:data\sensor\aquamonitor//cpu/0/temperature/0_0</connection> |
<-geht nucht hab schon bemerkt das hinter dem mehr infos wie nur der wert stecken
Source code |
1 |
Text="{Binding ElementName=this, Path=service_data:1:data\sensor\aquamonitor//cpu/0/temperature/0_0, FallbackValue=no data available}"
Quoted
bisher weiss ich das da drin einmal value & name drin sind. Sonst noch irgendwelche werte ? This post has been edited 1 times, last edit by "Saint" (Aug 23rd 2019, 3:12pm)
das geht nicht.Text="{Binding ElementName=this, Path=service_data:1:data\sensor\aquamonitor//cpu/0/temperature/0_0, FallbackValue=no data available}"
Source code |
1 |
service_data:1:data\sensor\aquamonitor//cpu/0/temperature/0_0 |
