Du bist nicht angemeldet.
Maki911
Freitag, 10. April 2020, 20:04
Freitag, 10. April 2020, 23:08
Please see attached pictures and post same ones.Yesterday I received almost all AC shipment and today I ve stared unpacking and connecting everything, so I decided to start with Farbwerk 360, out of 4 LED strips two wont light up and one have defective last LED light (its just blinking),when I tried to change colors, it gave mi this error... Nothing seams broken of flimsy on the connectors... Does anyone have any idea on what to do? try?![]()
Sorry, I totally forgot to take a screenshot....
Here you go, this is after channel 1 is connected with 3 LEDs strips, yes, cable connection is twisted OUT>IN direction and channel 3 with 1 LED strip. Channel 3 lights up and channel 1 just the first LED strip....
Tried again, one strip per channel, it worked until it flashed again the same error (Voltage out of range) and started red light blinking on the farbwerk 360...
Maki911
Here are the screenshoots you asked, is that good/bad?
3 connected strips work separately, I will try connecting them in one line to see if it will work... Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Maki911« (20. April 2020, 12:19)
Maki911
This is after connecting all 4 LED strips on one RGBpx channel. Is that ok value?
I cant change controllers(like just to have ambientPx-which doesnt work at all...) without auto -turning off LED strips 2-3-4, then just the first one works. After factory reset , it works again, all 4 strips on 1 channel.
