You are not logged in.
																		Dundys
This post has been edited 1 times, last edit by "Dundys" (Nov 16th 2020, 3:53pm)
																		Dundys
This post has been edited 11 times, last edit by "Dundys" (Jan 2nd 2021, 12:57am)
																		Dundys
Saw your post from yesterday and I checked the status on my aquasuite... everything was checked (default?), so I deselected all. I don't use that anyway.
Today all are still deselected. I will monitor over the next few days and advise. Shouldn't matter, but I have no HDD, all SSD.
This post has been edited 3 times, last edit by "Dundys" (Jan 2nd 2021, 8:08pm)
																		Dundys
Yah, just leave it for a while longer if you don't mind. As I mentioned, it might take few days, even week or so and it just happens all of the sudden when you least expect.It's been a couple of days since I deselected all Hardware Monitoring options, and no change so far... all still deselected. [attach]7977[/attach]
																		Dundys
This post has been edited 6 times, last edit by "Dundys" (Jan 5th 2021, 1:59am)
																		Dundys
Do you have your services start up delay at 3, 5 sec. or higher #. Originally I had mine 3 sec. then I changed it to 5 and was still acting up. Today I have adjusted to 6 sec I honestly doubt, but lest seeYah, just leave it for a while longer if you don't mind. As I mentioned, it might take few days, even week or so and it just happens all of the sudden when you least expect.It's been a couple of days since I deselected all Hardware Monitoring options, and no change so far... all still deselected. [attach]7977[/attach]
Although, I reloaded my windows 10 once again so everything is fresh and it has been good for 2-3 days now, but then again I had that many times before...let’s see.
Thanks
							This post has been edited 1 times, last edit by "Dundys" (Jan 7th 2021, 8:01am)
																		Dundys
																		Dundys
I appreciate your feedback the acknowledgement, thank you.This error only occurs with very few systems.
Most of the known problems occur when more than 2 monitoring programs are running at the same time. Also RTSS causes problems again and again because the program hangs itself virally in other software.
We know the problem, but could not reproduce or localize it.
																		Dundys
