Sie sind nicht angemeldet.
Dundys
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Dundys« (16. November 2020, 15:53)
Dundys
Dieser Beitrag wurde bereits 11 mal editiert, zuletzt von »Dundys« (2. Januar 2021, 00:57)
Dundys
Saw your post from yesterday and I checked the status on my aquasuite... everything was checked (default?), so I deselected all. I don't use that anyway.
Today all are still deselected. I will monitor over the next few days and advise. Shouldn't matter, but I have no HDD, all SSD.
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Dundys« (2. Januar 2021, 20:08)
Dundys
Yah, just leave it for a while longer if you don't mind. As I mentioned, it might take few days, even week or so and it just happens all of the sudden when you least expect.It's been a couple of days since I deselected all Hardware Monitoring options, and no change so far... all still deselected. [attach]7977[/attach]
Dundys
Dieser Beitrag wurde bereits 6 mal editiert, zuletzt von »Dundys« (5. Januar 2021, 01:59)
Dundys
Do you have your services start up delay at 3, 5 sec. or higher #. Originally I had mine 3 sec. then I changed it to 5 and was still acting up. Today I have adjusted to 6 sec I honestly doubt, but lest seeYah, just leave it for a while longer if you don't mind. As I mentioned, it might take few days, even week or so and it just happens all of the sudden when you least expect.It's been a couple of days since I deselected all Hardware Monitoring options, and no change so far... all still deselected. [attach]7977[/attach]
Although, I reloaded my windows 10 once again so everything is fresh and it has been good for 2-3 days now, but then again I had that many times before...let’s see.
Thanks
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Dundys« (7. Januar 2021, 08:01)
Dundys
Dundys
I appreciate your feedback the acknowledgement, thank you.This error only occurs with very few systems.
Most of the known problems occur when more than 2 monitoring programs are running at the same time. Also RTSS causes problems again and again because the program hangs itself virally in other software.
We know the problem, but could not reproduce or localize it.
Dundys
