Sie sind nicht angemeldet.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Taubenhaucher« (18. März 2022, 12:43)
WinstonWoof
A Piece of softawre shouldn't allow itself to be installed if certain criteria essential to its operation aren't met.
WinstonWoof
There are thousands of software examples, including the big names, which do exactly this - You install them, they open up with a splash screen, start the app and build the window... and then ask you to input the licence key you're supposed to have purchased.
Most apps used throughout my industry, in most parts of the world, also do this.
At least with Aquasuite you get the option of installing an older one which will still work... and it's not as if users aren't aware of how this works. You get told this all over the place, from product pages to manuals to the app itself!f
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Taubenhaucher« (20. März 2022, 09:22)
We have all done it to some extent, only difference being some hold their hands up and admit it's their mistake.
WinstonWoof
It's the same old story i see it again and again when people just don't take the time to stop and read instructions, it can be for computers or putting a desk together etc. They rush in break something, go back read the instructions and then complain that it wasn't clear.We have all done it to some extent, only difference being some hold their hands up and admit it's their mistake.
