 31.10.2025, 13:04
31.10.2025, 13:04 Sprache ändern
 Sprache ändern
						 Registrieren
 Registrieren Anmelden
 Anmelden
											Du bist nicht angemeldet.
																														 funnelweb
																		funnelweb
I contacted EK about the CryoFuel conductivity and I got a response directly from their "QA and coolant providers". These are the most important parts:
I contacted ek and asked about the conductivity of mystic fog and they said the conductivity is not available to the public!!
The average conductivity of EK-CryoFuel Clear Premix is 2.33 mS / cm2 or 2330 µS / cm2. Conductivity is measured during production and when charged with a certified and calibrated conductivity meter, at 20 ° C. The high conductivity is due to the corrosion inhibitor (confirmed by tests). The inhibitor is located in the liquid and upon contact with the reactive metal (copper, aluminum, iron) forms a protective layer and thus prevents corrosion, while being consumed. The more inhibitor is consumed, the lower the conductivity of the fluid.
As far as I was able to deduce from the e-mail below (my e-mail), the Aqua Computer High Flow NEXT sensor is used to measure the conductivity of distilled water. As a result, it is calibrated to a lower value. On the website, the manufacturer (AquaComputer) states that the reading reads between 2 and 200 µS. Given that the EK-CroyFuel Clear Premix has a conductivity 11x higher than the maximum where the sensor is calibrated, the readings are certainly not correct. A sensor calibrated at least in the range of 1-5000 µS would be needed for proper measurement.
The manufacturer's (AquaComputer) website also states: “If corrosion occurs or if the corrosion protection inhibitors are used up, the conductivity of the coolant increases significantly. In this case, the coolant should be replaced." This is not entirely true (for EK CryoFuel), because until the corrosion inhibitor starts to work, it is present in the liquid, hence the high conductivity. Over time, the inhibitor is consumed because it blocks corrosion and the conductivity of the fluid begins to decline. However, this statement holds true for distilled water; the greater the presence of corrosion in the system, the higher the water conductivity.
The quality of the coolant (CryoFuel) based on conductivity can be assessed, but not with the said sensor (too small range, I don’t know if it has a calibration certificate). The conductivity of EK-CryuFuel Clear Premix ranges between 2200 and 2500 µS. Conditionally the liquid is OK up to 1500 µS, if of course, the other properties are OK - color, sediment. If the liquid is clear / slightly yellowish, with a characteristic odor-free odor, the liquid is OK.
Could I have a different unit for the volume, its now at around 1 million litres so it not such a practical unit anymore.
the standard SI prefixes would be fine. even in the play ground there is no other units for volume
																														 RuffHi
																		RuffHi
																														 RuffHi
																		RuffHi
grab all the wires firmly, flat, and pull
the very small white connector is for quadro and octo yes.
And no it doesn't extend your aquasuite update subscription. it is not a USB device.
Q1: just grab all wires close to the connector, wiggle and pull at the same time.
Q2: I don´t think so, because you need an additional Device to read the flow signal (e.g. Quadro or Aquaero) with a (expired or active) license.
Q3: Yes, the spare connectors are for other Devices such as Quadro, Octo, etc with smaller sockets
 English forum »
 English forum » Two High Flow Sensors - One Aquaero 6 LT
											(6. April 2020, 06:21)
										 English forum »
 English forum » How to connect an Aquaero 6 PRO to a 6LT as slave. Fan control questions.
											(7. April 2019, 22:52)
										 English forum »
 English forum » flow meter
											(5. Juni 2017, 08:55)
 flow meter
										 English forum »
 English forum » Need assistance with High Flow Meter USB Setup.
											(4. August 2013, 02:52)
										 English forum »
 English forum » aquaero5 xt
											(4. August 2013, 08:56)
 aquaero5 xt
