• 12.05.2026, 06:42
crazy8s846
I cant speak german, but heres my water cooling
Sonntag, 29. August 2010, 22:53
Heres my computer just finished the watercooling today.
»crazy8s846« hat folgende Bilder angehängt:
_Maxi-
Sonntag, 29. August 2010, 23:51
is this a Haf X?
is there enough space for a watercooling?
what hafe you for a radiator?
crazy8s846
Montag, 30. August 2010, 00:20
is this a Haf X?
Yes it is a HAF X
yes there is room in it for watercooling as you can see
I have a black ice 2 mounted in the top of the case, with 2 san ace 4011 fans.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »crazy8s846« (30. August 2010, 00:22)
Sebl
Montag, 30. August 2010, 00:47
The Reservoir is from Dangerden isn't it? Quite interesting object as i can see on pictures but quite expensive.
How do you Fill the Watercooling System? through the reservoir it should be quite difficult.
crazy8s846
Montag, 30. August 2010, 00:54
Yes you are right, and it is not to bad turn it upsidedown, and take out 4 screws. I could have made it easier, but i dont think it would have looked as good.
Montag, 30. August 2010, 08:58
i like the position of the reservoir, different from the mainstream. In my opinion the tubing is to fat.
RedFlag1970
Montag, 30. August 2010, 09:17
Nice tubing,
but in my opinion its really too fat ^^
Sappibaer
Montag, 30. August 2010, 13:33
Thats a very nice System.
I like it :)
Out of Style, but it's Retro!
crazy8s846
Freitag, 3. September 2010, 02:12
:DHey thanks guys, i got my leds for my waterblock and put them in. I like fat tubing, high flow :thumbsup:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »crazy8s846« (3. September 2010, 02:48)
Sappibaer
Freitag, 3. September 2010, 19:40
Looks very nice with the LED's :thumbup: 8o
