• 16.04.2026, 02:32
Pawls
ENG:Frontplatten Designer, Aquatube
mardi 26 octobre 2004, 23:01
Hello! Sorry for using english, but this is the only place to ask!
I´m looking for a template/cad for an aquatube mountingplate done in Frontplatten Designer. If someone has one; please share it with me! :D
Frontplatten Designer: http://www.schaeffer-apparatebau.de/
- PAWLS
NikoMo
NikoMod
Re: ENG:Frontplatten Designer, Aquatube
mercredi 27 octobre 2004, 09:40
hi,
english is not a problem for us ;)
i don't have a file for the frontplatten designer. but if you want, i can post the measures from the mountingplate :)
http://www.nikomo.de/pics/blende.wmf
DeViLSpArK
mercredi 27 octobre 2004, 15:23
wait a moment i can make it....
Please visit www.moddingecke.de Biete Aquagrafx ->Pn
DeViLSpArK
mercredi 27 octobre 2004, 15:38
ich hab ein problem, wo kommen die eingekreisten löcher hin ? radius und größe stimmt nur die position nicht :-/
Chewy
mercredi 27 octobre 2004, 15:40
DeViLSpArK
mercredi 27 octobre 2004, 15:42
ja aber ich weiß nicht wie weit hoch oder runter die müssen, oder die löcher am rand, welchen abstand die zumm rand haben
Pawls
mercredi 27 octobre 2004, 16:06
Thank you! The blende.wmf helps out alot. I´m going to try to make one myself. I´ll post it if I succseed. I could need some help with positioning the five mounting holes. How do I calculate thier position and angle?
DeViLSpArK
mercredi 27 octobre 2004, 16:22
Citation de "Pawls"
that`s my problem, i don`t know :-/
dami1233
mercredi 27 octobre 2004, 16:24
360° / 5 = 72 °  ;)
regards
dami
edit:
I´ve did it in ten minutes. Just give me your email address so I can send you the cad file. instead of the five "eggform" holes I´ve constructed round holes - but this should fit!
edit2:
picture: push it
Pawls
mercredi 27 octobre 2004, 19:07
Ah! (I could figured that out, but I was in a hurry ;D)
Pawls
mercredi 27 octobre 2004, 20:00
I´M DONE! :D
With the messurments from blende.wmf I´v created the mounting plate in frontplatten designer. I had to brush up my trigonomy a bit first :)
Here it is: http://www.lndbrg.net/skrot/aquatube.fpd
( I don´t own an aquatube (yet), so maybe someone could confirm it by print it and compare, but it should be exact )
PAWLS
saUerkraut
mercredi 27 octobre 2004, 22:31
Nice work...but Ive got somewhere the file you have searched.^^
greets
