• 14.03.2026, 05:48
TrOuble
Cinema 4D - beim starten fehler ?
Mittwoch, 14. Dezember 2005, 14:29
Moin,
Hab mir ebene Cinema 4D installiert, weil ich mal bisschen damit rumspielen möchte.
Leider kommt direkt beim starten dieser Fehler :
Den Report würd ich gern reinstellen, allerdings kann man den nicht kopieren *toll gemacht ms*
In der TMP zur Fehlermeldung steht das :
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="CINEMA_4D.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="CINEMA_4D.exe" SIZE="7729664" CHECKSUM="0x3B86E0CF" BIN_FILE_VERSION="8.0.0.1" BIN_PRODUCT_VERSION="8.0.0.1" PRODUCT_VERSION="8, 0, 0, 1" FILE_DESCRIPTION="CINEMA 4D ®" COMPANY_NAME="MAXON Computer GmbH" PRODUCT_NAME="CINEMA 4D ®" FILE_VERSION="8, 0, 0, 1" ORIGINAL_FILENAME="CINEMA4D.exe" INTERNAL_NAME="CINEMA 4D ®" LEGAL_COPYRIGHT="Copyright © 1989-2002" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.0.1" UPTO_BIN_PRODUCT_VERSION="8.0.0.1" LINK_DATE="09/07/2002 22:30:11" UPTO_LINK_DATE="09/07/2002 22:30:11" VER_LANGUAGE="English (United States) [0x409]" />
<MATCHING_FILE NAME="MSVCP60.DLL" SIZE="401462" CHECKSUM="0x5914448B" BIN_FILE_VERSION="6.0.8168.0" BIN_PRODUCT_VERSION="6.0.8168.0" PRODUCT_VERSION="6.00.8168.0" FILE_DESCRIPTION="Microsoft (R) C++ Runtime Library" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft (R) Visual C++" FILE_VERSION="6.00.8168.0" ORIGINAL_FILENAME="MSVCP60.DLL" INTERNAL_NAME="MSVCP60.DLL" LEGAL_COPYRIGHT="Copyright (C) Microsoft Corp. 1981-1998" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x69F69" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="6.0.8168.0" UPTO_BIN_PRODUCT_VERSION="6.0.8168.0" LINK_DATE="06/17/1998 18:52:10" UPTO_LINK_DATE="06/17/1998 18:52:10" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x4CE79457" BIN_FILE_VERSION="5.1.2600.2180" BIN_PRODUCT_VERSION="5.1.2600.2180" PRODUCT_VERSION="5.1.2600.2180" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF848" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.2180" UPTO_BIN_PRODUCT_VERSION="5.1.2600.2180" LINK_DATE="08/04/2004 07:56:36" UPTO_LINK_DATE="08/04/2004 07:56:36" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
Auf meinem Rechner läuft Windows XP mit SP2 und allen Patches.
MfG TrOuble
Re: Cinema 4D - beim starten fehler ?
Mittwoch, 14. Dezember 2005, 15:46
Könnte unter Umständen etwas mit der Grafikkarte bzw. deren Treiber zu tun haben. Stell vielleicht mal wieder alles auf default und probiers mal erneut.
TrOuble
Mittwoch, 14. Dezember 2005, 15:57
Hab nochmal nen Screenshot gemacht von der erweiterten Fehlermeldung :
Scheinbar hat es was mit Quicktime zu tun.
Quicktime ist scheinbar bei mir defekt - habs versucht zu deinstallieren und dann kommt der Fehler :
Gibts ne andere möglichkeit Quicktime zu de/installieren ?
(wenn ichs drüberinstallieren will, sagt er,dass QT schon installiert ist ...)
