• 15.12.2025, 15:02
Stuermer
Was bewirkt SYMPROXYSVC.exe?
Saturday, May 22nd 2004, 7:02pm
Habe nach dem ich formatiert habe meinen Rechner öfters 100% ausgelastet! Im Task Manager steht, dass die SYMPROXYSVC.exe dafür verantwortlich ist!
Was bewirkt die Datei?
Kann ich die schließen?
Gruß Felix
HoferSackal
Re: Was bewirkt SYMPROXYSVC.exe?
Saturday, May 22nd 2004, 7:05pm
Bentuzt du Symantec Sachen?
http://board.protecus.de/showtopic.php?threadid=348
oder mal nach "SYMPROXYSVC.exe" googlen ;)
zeppe
Saturday, May 22nd 2004, 7:11pm
Symantec's "Norton Personal Firewall" has a bug which may prevent Teleport Pro from accessing files on the Internet. Symantec has resolved the problem in its Live Update of their software, as of October 29, 2001. If you haven't updated your firewall software, a successful workaround is to turn off the Norton Personal Firewall, or to rename the file "SymProxySvc.exe" to "SymProxySvc.bak" and reboot your system. (Remember to rename that file back to "SymProxySvc.exe" if you want to resume using Norton Personal Firewall.)
Athlon
Cyrotech
Sunday, May 23rd 2004, 1:38pm
CPU: Intel Core2Duo E6600
HD: 2x 500GB SATA Samsung
Sound: Audigy2ZS Platinum Pro
Eumel
Sunday, May 23rd 2004, 2:47pm
4 MB Speicherauslastung bei mir.
0 % Prozessorauslastung.
Ist von Norton. Mich störts nich.
