• 10.10.2026, 01:14
posedatull
Question about the logic behind whoever designed the Airplex Modularity radiators
Dienstag, 29. September 2026, 20:23
I bought a few Airplex Modularity radiators, both 360mm and 480mm ones, initially intending to put them al into a Corsair 9000D case. I was aware of the sizes, but somehow, it didn't register in my head just how wide they are.
Clearly they cannot fit in one of the largest cases on the market, unless I install just one in front and one up top, which would basically defeat the whole purpose of a 9000D case... so I figured I'll just use them for a secondary build.
Now comes the issue: been spending the last 2-3 days looking for cases where I could fit two Airplex 480mm radiators, just to figure out they basically do NOT fit in most cases due to their width. Even the 360mm ones have the same issue in most cases.
Who designed these, which cases on the market were they looking at, if I may ask?
I love the feel, they actively feel like THE most high quality and durable radiators I've ever touched (and I've only been building loops for a decade), but how can people buy more when they're practically unuseable in the vast majority of cases on the market?
Ordered an EnthooPro 2, in the hopes I'll be able to force the two 480mm inside it...hopefully.
Jacob
Freitag, 2. Oktober 2026, 00:34
Modular heat sinks are basically externally mounted.
IMG_9239 by Jacob Tien, 於 Flickr
