• 20.05.2026, 10:34
brutalix
Trouble updating the aquastream xt via aquaero 5.
Donnerstag, 28. Juli 2011, 23:48
Hi .
I just bought aquaro 5 for 2 reasons:
1. Fan controller.
2. Being able to update pumpfimrware. (Don't have a computer with paralell port.)
I have a problem with firmware updating. It might be an very obvious solution that might be posted already, but when I search i mostly find german posts, and I dont speak german.
I start Aqua suite 4.72., then i go to update. It shows my pump with firmware 1.003 and new firmware 1.017 But dont get a button/question to update.
Where and how in aqua suite do i find the firmware update option?
Kind regards
Brutalix
Freitag, 29. Juli 2011, 09:58
That kind of update can only be performed with the aquaero 3.07 or 4.00. That solution was already a dirty workaround which is not possible anymore with the aquaero 5.
If you want to get it updated you could also unsolder the controller and send it to us. Shipping costs should be cheap in this case and the shipping back to you would only cost 5,00 EUR. Of course that might take a few days depending on your location.
