• 26.03.2026, 14:08
gaspin16
replacement display aquaero5 xt
Montag, 8. August 2011, 23:42
hi, yesterday I accidentally plugged the wrong power supply :cursing: and even though I promptly disconnected the AE5 I smelledsomething burning ;( . I reconnected in the right way and it seems that everything works except the display has a golden line that causes me some discomfort. I would like to know if there is the possibility of replacing just the display, such as spare part. if so, how can I order it and if I can replace it myself :?: .. thanks ..
Donnerstag, 11. August 2011, 10:59
The display is only plugged to the other boards so you can easily exchange it. To order a new one you have to contact info-at-aqua-computer.de since the display is not available through the webshop.
