• 27.03.2026, 03:51
Silvermaul
Flow sensor High Flow stopped working
Samstag, 10. Dezember 2011, 13:05
Hi all,
I just noticed the little red light on my pump XT Ultra
and then opened the Aquasuite 4.72. Flow sensor seems dead. 0.0 l/h.
This happened without me changing anything at all. Water is of course flowing, and everything is working fine. I tried resetting the setting on the pump, disconnecting/connecting the sensor etc.
Nothing. It stays to 0.0 forever...
Anyone had this before?
wramey
Sonntag, 11. Dezember 2011, 23:34
This also happened to me several weeks ago. I reset the A5 XT to the factory defaults and all was well. I have no idea what caused it nor has it happened since. NOTE: I do not have the XT Ultra pump.
DayRider
CaseLabs TH10A (Black) + Pedestal
2x Corsiar 1200i PSU (w/ mini-Commander Link)
Asus Ramage V MOBO
i7-5960X, 3 GHz, L3 20 MB, TDP 140 Watt, 8-core, Hyper-Threading
16GB Ballistix Sport DDR4 2 2.4GHz
2x GeForce GTX Titans
4x Samsung 850 Pro 1 TB SSD Drives
AC6 Pro, 2x PA3 Ultra, Flow and Tube Meters, 1x Farbwerk
2x Aquacomputer D5 pumps with USB
5x OCOOL Radiators + 53 PWM fans
2x ViewSonic V3D245 26inch Monitors
Silvermaul
Montag, 12. Dezember 2011, 00:11
I connected it now to the aquaero 5 LT that I have. In the flow port. It also says 0.0 l/h.
I don't understand how this could happen? I mean OK I have it for 6 months but I would assume that It should last more :) That thing ain't cheap too..
I will wait for some Shoggy answer. If there is anyone who knows what could be wrong its him.. I hope I don't have to RMA the thing because in the spot it is now I will have to dismantle a large part of my loop to get it out..
