• 09.05.2026, 00:09
tnc99
Show water temperature in display aquaero 5
Donnerstag, 23. Februar 2012, 22:38
If it is possible, how do i show water temperature like this:
http://forum.aquacomputer.de/images-ac/ae5_pro_edelstahl.jpg
From my Aquastream XT?
Thanks!
Peter
I7 2600K
6990+6970 Watercooled EK-Plexi Crossfire
Gigabyte GA-P67A-UD7
Coolermaster Silent Pro Gold 1200W
Corsair Obsidian 800D
2 x Crusial C300 Raid 0
Corsair vangance 2x4G
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
etoel
Freitag, 24. Februar 2012, 00:31
As I recall you go into the log collection and assign your water temp sensor to it and then configure the information page (graph) to display that log.
gullars
Freitag, 24. Februar 2012, 00:34
Yes, but first you have to create a data log for the water temperature sensor in your Aquaero and select the right information page: menu-> user interface-> information pages-> page 1(or desired page)-> select information to be shown-> chart from data log-> logdata 1(or desired).
Its possible there is another way to it, but this is the only one that I know of :)
tnc99
Freitag, 24. Februar 2012, 11:09
Thanks! but how do i create a data log for it? maybe a step by step guide.
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
gullars
Freitag, 24. Februar 2012, 13:09
Menu-> Datalog-> Datalog config.-> Data set 1(or desired)-> Interval (whatever you want), and data source (select the water sensor). Afterwards you must do the steps in my last post to get the chart on display.
tnc99
Freitag, 24. Februar 2012, 13:59
Got it now, thank you.
Hope it will be inplementet in aquasuite soon.
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
