• 14.04.2026, 05:41
Mr_Armageddon
USB Power Adjust Software Question
Dienstag, 3. April 2012, 23:34
Hello. I recently purchased a Aquaero 5 LT, and two (2) USB Poweradjusts to control my pumps. My question is, are the PowerAdjusts stand alone? Will they run with their own software when plugged in via USB, or do they require the Aquaero 5 to function properly.
Reason I ask is that I have been offered by Corsair to sponsor my new build, and they want me to use their new "Link" system along with their PSU and RAM. It works fine for fan control, but has NO Pump Control. If I were to remove my Aquaero 5, will my PowerAdjusts still function properly, running by themselves? Thank you in advance for any help offered.
Nihil Simile
Dienstag, 3. April 2012, 23:49
Yes it will work stand alone or with any Aquaero.
Mr_Armageddon
Mittwoch, 4. April 2012, 00:04
Great news. I may still keep the Aquaero 5. Corsair is sending me the Link unit to play with, but I didn't want to lose my pump control. If it doesn't pan out to be that great, I will stick the Aquaero 5 back in.
Thanks for your help.
