• 08.04.2026, 23:04
aknewhope
Airplex modular unit(33010) dimensions
Mittwoch, 11. April 2012, 01:53
Hello. I am interested in purchasing the Airplex 33010 modular unit from frozencpu.com but there are no detailed dimensional information anywhere to be found. Is there such a thing available?
Donnerstag, 10. Mai 2012, 14:35
The basic dimensions (in mm) of the radiators are always
Length: fan size + 44 (e.g. 3 x 120 + 44 = 404)
Height: 63.5
Width: 146
The variants with a pump and integrated reservoir are 25 mm higher (= the height of the fans).
The pump modules without the pump are 26 mm longer so you have to add a total of 70 mm to the fan size.
The D5 pump sticks out another 36.5 mm while the compact 600 pump sticks out 35 mm downward.
The optional reservoir adds 26.5 mm to the length.
Example for a 3 x 140 mm radiator:
Length: 3 x 140 + 44 = 464
Height: 63.5
Width: 146
