• 22.02.2026, 01:28
Rjrolyn
Suggested fan channel for 3 Lian Li Fans in one channel....
Donnerstag, 12. April 2012, 06:47
Hi everyone...
As the title says... I have the A5xt and needing info to which fan channel to use for 3fans in 1 channel. I have the Li-an Li's that im using from my old Lian Li 2000 case. I dont wanna burn out any fan channels out. Thanks in advance..
Donnerstag, 10. Mai 2012, 14:37
It does not matter which fan channel you use. They all provide the same amount of power (max. 1,65A @ 12V (=19,8W)).
To be able to use the maximum available power you will have to watercool the voltage regulators of the device.
