• 10.01.2026, 13:29
wado
how to make charts to aquaero 5 pro
Dienstag, 8. Mai 2012, 20:55
hi
I've got aquaero 5 up and running fine but how do i make a charts to be shown in the display of the aquaero 5 pro
i use aquasuite 2012 beta 14 on windows 7 64 bit
Thanks for your help
Thomas
mrpayne
Mittwoch, 9. Mai 2012, 01:35
In the Info page of AS2012 add a chart from the available charts (just start with chart 1).
From the Aquaero, select the "data log" and chose your data source (using the button menu), the available options (it will be a bit more intuitive if you name them within AS2012). Use the "save" button (floppy disk) to write to the Aquaero. Wonder if some folks are wondering what that the icon is. LOL
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »mrpayne« (9. Mai 2012, 01:40)
wado
Mittwoch, 9. Mai 2012, 13:17
thanks it worked
