• 20.03.2026, 22:29
jamel
Searching software sensor interface/data format documentation.
Wednesday, May 30th 2012, 5:24pm
First of all, good morning to all.
I was wondering if there is a documentation available (in English) on the interface - and data formats - used to provide software sensor data that can be imported into aquasuite?
In other words, I would like to know how I can generate my own counters from my applications so I can capture and use them to setup controls in my aquacomputer.
I believe that AIDA is one application using such mechanism to export counters via shared memory. I would like to do the same, but from my own application.
I am programming in C/Win32.
Thank you in advance for your help and directions.
Best regards,
-Jamel
Wednesday, May 30th 2012, 10:11pm
Hello,
a sdk is not available at this moment.
Sebastian
jamel
Saturday, June 2nd 2012, 4:16am
Hi Sebastian,
Thank you for your answer. I am looking forward using your SDK when it will be released.
Best regards,
-Jamel
