• 24.01.2026, 12:29
jano
RGB LED
Mittwoch, 13. Juni 2012, 21:42
Hello, you can connect two RGB LED aquaero 5 xt. thank you
cmdprompt
Donnerstag, 14. Juni 2012, 04:04
I have seen others on different forums that have without any issues.
Donnerstag, 14. Juni 2012, 12:53
No, only on of the RGB modul is allowed. You can try more a your own risk.
b0nez
Freitag, 15. Juni 2012, 13:00
There is a way to connect two or even more LEDs to the AE5.
This Guy developed a little device. Here ist the original thread and this ist the release thread of his RGBAmp.
Problem for you - all the thread and the explanations are in Germen. You may ask the guy if he can deliver an english version.
But Keep in mind that you use the RGBAmp at our own risk !
Cheers
:rolleyes:
cmdprompt
Samstag, 16. Juni 2012, 04:20
Any reason why? You would think the LED's would just be a bit dimmer.
b0nez
Samstag, 16. Juni 2012, 16:18
When adding more LEDs to the Port you automatically increase the load on the electronic components and may destroy them.
:rolleyes:
