• 20.03.2026, 05:12
showtime9876
Pa2 question! Help!
Samstag, 16. Juni 2012, 06:23
Hello everyone! I am from China,and I am sorry for my English.
I have a question about pa2 and I need help!
I have a auqaero5 and three pa2. I Connec them with aquabus like this.
http://public.blu.livefilestore.com/y1pV…1162.jpg?psid=1
And I set pa2 id 50/51/52
I have two KL FM17 and dual loop ,and I Connec KL FM17 to aquaero5.Set a calibration value of 197,One flow is about 2-2.1GPM,another one is about 1.4GPM and the value is very stable.
The question is when I connec FM17 to pa2,the flow is Irregular jumps,such as 0.XGPM,1.XGPM,2.XGPM, many different value and no rules.
Who can tell me why? How to solve? Thanks.
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »showtime9876« (16. Juni 2012, 08:32)
Montag, 18. Juni 2012, 13:09
Unfortunately I have no solution for this but I can tell you that I have read similar things from other users with that sensor. It seems that it is not compatible to the aquauero for an unknown reason.
showtime9876
Dienstag, 19. Juni 2012, 05:14
Whether there are the same things happened on other similar ?Yesterday,I have connec pa2 with usb,open aquasuite 4.72.00 and the same as before.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »showtime9876« (19. Juni 2012, 05:17)
