• 14.05.2026, 12:08
MDHellDK
Aquatube, aquajet and tubemeter
Sonntag, 12. August 2007, 20:17
Hi all, again ;D
is it possible to use aquajet and tubemeter in an aquatube??
even if the tubemeter touch the aquajet??
MDHellDK :D
Re: Aquatube, aquajet and tubemeter
Sonntag, 12. August 2007, 20:29
It is possible when you install the aquajet in the highest posistion and bend the tubemeter a bit to the side. That will not win a beauty award but it does work ;)
Or you cut down the tubemeter to the desired length.
The cut surface must be sealed afterwards!
MDHellDK
Sonntag, 12. August 2007, 20:32
Hey Shoggy, thx for really fast reply :D
i have mounted it as you mention, so i let it stay so :D
MDHellDK
