• 11.04.2026, 13:59
bob452
aquabox 5" screws
Freitag, 29. Juni 2012, 19:32
Hello everybody
I own one aquabox 5"1/4. Its a nice reservoir but i have some bubbles problems while testing it
There is 2 hexagonal screws in the aquabox , 1 in each upper corner, on the way of the water.
What are those 2 screws used for?
Can I screw/unscrew them a bit? Or is it tuned in factory and i should not touch them?
Can it solve my bubbles problem if I .... screw them?
Thanks and sorry for my poor english
hobbes_dmS
Montag, 2. Juli 2012, 23:33
hi,
with these screws you can adjust how much water flows across the "window".
just give it a try
