• 02.01.2026, 19:28
JayCub
Aquaero 5 pro
Freitag, 20. Juli 2012, 16:46
Hi Guys i purchased an Aquearo pro second hand and never received the usb connection to the motherboard and im wondering if i can buy it from the store :whistling: also wondering where i can get a hold of the manual, i intend to expand the amount of hardware i have, and some guys online are well versed, but i would prefer my own research 8o
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »JayCub« (20. Juli 2012, 16:48)
cc01
Freitag, 20. Juli 2012, 17:01
USB cable available from here: http://shop.aquacomputer.de/product_info…roducts_id=2573
You can download the manual here: http://aquacomputer.de/handbuecher.html?…_2011_08_22.pdf
The manual is rather basic though, but it gives you an idea of what connects where. :)
JayCub
Aquaero 5 pro
Freitag, 20. Juli 2012, 20:42
Thank you very much for the information, I have some idea, but i want to make sure that things are just right, rather than guess, i love the unit, and it came with the black bezel, so i can't complain too much, Cheers :thumbsup:
bcikota
Freitag, 20. Juli 2012, 21:15
Hi JayCub,
One of the best guides for Aquaero, although unfortunately incomplete, is still Martins review of the unit. Give it a look, it is worth it.
Kind regards,
Boris.
