• 16.03.2026, 16:32
nick2002a
Software Sensor Tool
Dienstag, 28. August 2012, 03:08
Hello People,
I'm staring to feel like quite a Muppet, but where can I find the Software Sensor Tool?? I have found several links over the pages, but they all seem to lead to nowhere (well, nowhere in English anyhow). I'm, trying to get the software sensors to work with AIDA64, I have found several threads that discuss this, but with out the sensor tool I am stuck.
Thanks
Stuart
cc01
Dienstag, 28. August 2012, 04:38
The link for the old software sensor tool seems to have been removed ... If you are using the latest Aquasuite (Beta 16) you don't need the Software Sensor Tool any more. Just make sure you have "enable writing sensor values to WMI" checked under "preferences/external applications" in AIDA64
cc01
Dienstag, 28. August 2012, 08:26
Also, if you have already installed the latest version make sure you remove the old Aquasuite from the startup menu as this has been known to cause conflicts with detecting the software sensors (while the new version is running).
nick2002a
Mittwoch, 29. August 2012, 02:25
Thanks cc01,
All is now functional. It has been a journey.....
Stu
