• 25.01.2026, 05:43
gaspin16
flashing LED on AE5
Mittwoch, 12. September 2012, 21:35
Hi, I have a problem .. Flashes a red LED above the connector at aquabus2 of AE5 .. What's this? ?( Should I be worried? ;(
LarryWill729
Mittwoch, 12. September 2012, 21:47
Flashing red LED is bling left over from product R&D.
Ignor it or enjoy it.
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
Donnerstag, 13. September 2012, 10:01
You should be only worried if it does not light up at all because then your aquaero is dead ;)
