• 31.10.2025, 23:17
pegleg
aqauero5 xt how do i set this to control my fans on rad with temps internal ....
Donnerstag, 25. Oktober 2012, 13:13
ohh boy what did i do now,this seems hard to set everything.i have auqstream xt pump and flow sensor(53129) and the aquaero 5 xt.can anyone help me or give me some idea how you set this up to control my 6 fans,i already have it hooked up just need to have some idea how you get the software to control the fans.i have tried to look for video or something to help explain how i can do this. or do i use the preset that they have in the aquaero 5 xt .wish they had something to explain more on this.does anybody have or know of anything on how to set this up.
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »pegleg« (26. Oktober 2012, 06:51)
cc01
Freitag, 26. Oktober 2012, 13:19
You can get the software here: http://aquacomputer.de/software.html Download the Aquasuite 2012 BETA 16. You also need Microsoft .NET Framework 4 installed before you install Aquasuite which you can get here: http://www.microsoft.com/en-us/download/…s.aspx?id=17718
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »cc01« (26. Oktober 2012, 13:29)
pegleg
Freitag, 26. Oktober 2012, 13:58
thanks
