• 25.03.2026, 19:25
nickolp197
Urgent help required
Sonntag, 4. November 2012, 12:33
hi have got this top, Koolance Laing D5 Pump Top and Reservoir Base Rev 2.0 : COV-RP450 and i have the aquacomputer D5 with aquabus and the problem is the clamp ring, i cannot use use the supplied one with this pump, do AC make one which will work? i presume they have one with there aqualiss top/res. Can these be bought?
Montag, 5. November 2012, 11:20
You can get this ring as a single part but I am pretty sure that this will not work because of a different design.
