• 12.03.2026, 15:02
DrunkenJim
Software Sensor problems, Windows 8
Tuesday, November 13th 2012, 11:18pm
Hello all,
i'm having a problem getting the software sensors to work, ever since updating to win 8 i get a blank selection window as below screenshot.
strange thing is it still shows my previous windows 7 selection as already being selected, but it still just sits at the default 50 deg.
I have upgraded to release 1 and firmware 1026, but same result.
thanks in advance for any help,
Jim
This post has been edited 1 times, last edit by "DrunkenJim" (Nov 13th 2012, 11:22pm)
Wednesday, November 14th 2012, 3:00pm
That is a problem of Open Hardware Monitor. You can try to use the previous version or if you have some programming skills download the source code and compile it because for some strange reasons this will also work correctly.
DrunkenJim
Wednesday, November 14th 2012, 3:08pm
Thanks mate, downloaded 0.40 beta, all works now.
