• 24.03.2026, 06:14
oyvjohns
Aquasuite upgrade?
Donnerstag, 15. November 2012, 08:53
Hello all.
I have a litle trouble finding out which upgrade is the newest.
Im still running Beta 10 and have done so for about 1 year now without any issues, but now im interested in trying a newer version.
But i have some questions about this:
What is the latest version and where do i get it?
Is it possible to save my setup on Beta 10 version and import it to a newer version.
What is the changed from Beta 10, is it worth it to change to a newer one when the one i got works perfect?
Best regards.
Donnerstag, 15. November 2012, 09:37
The lastest Version is always here:Suppport -> Downloads
You cant use any settings from the old aquasuite when you do a upgrade.
oyvjohns
Donnerstag, 15. November 2012, 11:29
Thanks for the info.
New version installed and after alot of pain and bad words, everything is working properly.
To me it seems like this new version is a bit slover when trying to change a setting or opening a new page?
Cant belive that its so because of my computer, running CPU at 5 GHz so maybe its because of the Aquacomputer?
Can you confirm this?
Regards.. Ø
Donnerstag, 15. November 2012, 16:24
The loading time depends on how much stuff is visible on the site. The example page for the aquaero already contains a lot of stuff which takes some time to load.
