• 21.03.2026, 03:17
LarryWill729
Aquasuite 2012 math error
Donnerstag, 15. November 2012, 20:29
Virtual Temperature Sensor still has math error when calculating differential temperature in Fahrenheit (F).
For example, a differntial temperature of 1 C does not equal a differntial temperature of 33.7 F.
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
Freitag, 16. November 2012, 08:59
Internally the device works with Celsius. The difference can not be simply calculated correctly by the aquaero because of a necessary formula (°C = (°F - 32) * 5/9) and further calculations.
That will not change in the future since it is way to complicated too integrate this in a useful manner.
