• 04.04.2026, 22:07
Psychor
What does "RE" mean?
Sonntag, 18. November 2012, 01:14
Running an AQ5 Pro w/ firmware 1025. What does the "RE" mean? It's displayed at the bottom right of my display?
Thanks.
Mittwoch, 21. November 2012, 15:33
This is AE and not RE ;)
AE stands for aquaero and means that your remote control is currently working in the menu structure of the aquaero. Next to the larger round mouse navigator button you have another button with two squares. Press it and the text will change to PC which means the remote will control the PC now.
The text just indicates with remote control mode is currently active.
Psychor
Samstag, 24. November 2012, 06:06
Whoops - thanks Shoggy. My AQ5 didn't come with a remote. Should I still be seeing this icon?
Montag, 26. November 2012, 10:18
Yes, the aquaero 5 PRO shows it also since it has the same infrared receiver like the XT.
_KaszpiR_
Samstag, 4. Mai 2013, 20:15
Is it possible to make this element disappear?
It annoys me, and I don't have remote control.
related:
Cutom logo and RE in bottom right corner
_KaszpiR_
Sonntag, 12. Mai 2013, 16:26
Interesting, after power reset the AE mark is gone.
