• 31.03.2026, 03:37
cc01
airplex GIGANT 3360 & 1680
Sonntag, 25. November 2012, 04:07
To the AC people,
The airplex GIGANT 3360 & 1680 dimensions in the AC shop are both listed as 310 x 310 x 540 mm. What are the correct sizes for each of these items? Also, what do the numbers 3360 & 1680 refer to?
They look like fantastic products!
Thanks in advance. :)
jpmboy
Yes they do
Sonntag, 25. November 2012, 22:17
Look fantastic! I think 1680 refers to 4x 420 rads. Incredible cooling capacity.
I'm seriously thinking of how i can use the 1680 copper version... If for nothing else but looks!
AsRock E3Gen3, 2700k @4.6 with cuplex HF, 2 HD7970s with aquaC waterblocks, 16G GSkill 2133, TJ09, ST1500 ps, plextor 256 ssd, 2x1TB WD VRs raid 1, HP 30 inch. Aquacomputer 720XT Mk IV.
cc01
Montag, 26. November 2012, 07:36
Ahh I see. Thanks. So the 3360 would be 4 x 840? Can that be right? The thing is huge!
Montag, 26. November 2012, 10:25
310 x 310 x 960 mm
cc01
Montag, 26. November 2012, 10:46
Thank you.
