• 13.04.2026, 06:07
Psychor
Flow question - Aquacomputer Airplex Mod. Rad.
Mittwoch, 16. Januar 2013, 05:30
Would the configuration (e.g., flow direction) below work? Click the image and follow the RED arrows for the flow direction. It should but I just wanted to double check. ;)
Thanks.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Psychor« (16. Januar 2013, 05:31)
SNTmods
Mittwoch, 16. Januar 2013, 08:51
Im not sure if that can be done or not but have you considered just rotating the 2nd modular radiator 180 degrees so it pairs up as it should?
Was an early adopter of Aqua-Computer watercooling in the U.S.
Psychor
Mittwoch, 16. Januar 2013, 08:54
I have them oriented like this for a reason. But thanks for the suggestion. ;)
