• 09.04.2026, 00:41
snef
Aquasuite 2012 -5 cpu usage
Freitag, 8. Februar 2013, 00:50
i have aquaero 5 XT with 3 poweradjust 2 ultra
on Aquasuite 21012 -5
and i want to know if its normal to have a lot of cpu usage with aquasuite 2012 running?
i have a constant 30% of usage on core 1 and core 3, core 2 and 4 stay a 0-1% (intel i7-3770k)
aquasuite 2012 -6 have the same usage?
and if everything is set to what i want, do i need aquasuite open or the aquaero will controll everything?
thanks
Jeremy
Freitag, 8. Februar 2013, 03:05
What, exactly, has to be running for fan control?
I only get CPU usage even close to that when Aquasuite has been running for 12-15 hours. Closing it and re-opening it solves it, seems to be a memory leak. I'm currently on Aquasuite 2012-6
