• 15.04.2026, 20:24
adrianwc
Aquaero 5 support for more than 4 mps devices?
Dienstag, 26. Februar 2013, 09:29
Hello,
will someday Aquaero 5 support more than 4 mps devices?
in my loop I have:
2 x Aquacomputer D5 USB
1 x Aqualis XT with fill level sensor (its mps delta 40)
1 x High Flow USB
1 x mps delta 500
so I'm missing one channel for mps device and have to resing from some functionality of my system
cc01
Mittwoch, 27. Februar 2013, 02:41
You could use the older type flow meter (there is a high flow version) to free up an mps channel. There is a dedicated 3-pin header on the aquaero for this device.
Buckey
Donnerstag, 7. März 2013, 08:23
I would like to see more fan channels too.
Donnerstag, 7. März 2013, 08:55
you have max. 12 Fan channels, AE5 = 4 + 8x PA2
When you need more you have to buy a second aquaero.
