• 12.05.2026, 13:10
Namron
Aquasuite 2013 V.1 Not picking up Aida64 "Software sensors"..
Freitag, 22. März 2013, 21:56
I've just noticed as I've been going through re-setting up everything that for some reason my Aquasuite 2013 V.1 update is no longer picking up the temps from Aida64 for the Software Sensors settings screen..
Was wondering if anyone else is having this problem or is it just me!! :) ...
N.
EDIT** Ignore that... Sussed it now... (I had a NUMPTY moment sorry :rolleyes: ) I hadn't restarted/re-installed the Aqua Computer Windows service, Now i've re done this all is well again :thumbsup:
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Namron« (22. März 2013, 22:35)
snef
Freitag, 22. März 2013, 22:43
same thing here
reboot, nothing
need to reinstall over the same version and it work
Namron
Freitag, 22. März 2013, 23:01
I didn't need to re-install the whole Aqusuite 2013... I just had too restart the "Aquasuite with Administrator rights" & then click on the "Install" the "Aqua Computer Windows Service", Once I had done this then all the Software sensor readings were back & functioning properly..
N.
