• 06.01.2026, 09:52
WoodSpoon
Aquaero 5 PRO or XT?
Montag, 20. Mai 2013, 23:00
I'm in the market for a new Aquaero.
Finally got fed up with my Aquaero 4's usb connection issues, so what I'd like to know is.
What's the main real world difference between the Aquaero 5 PRO and the XT version?
The main difference I can see is that the XT comes with a huge remote that I'll never use and touch screen buttons, is there anything else, because I'm siding with the Pro version.
Grasshopper
Dienstag, 21. Mai 2013, 02:08
yes
Pilo
Dienstag, 21. Mai 2013, 04:35
The XT, Pro and LT version use the same printed circuit board.
The differences are the displayes.
LT = none
PRO = Display with 3 normal control buttons
XT = Display with 7 touch sensitive buttons
bern43
Dienstag, 21. Mai 2013, 15:00
I had to shut the touchscreen off on my XT because it would constantly register false clicks. If I could go back I would've purchased the Pro.
WoodSpoon
Dienstag, 21. Mai 2013, 19:29
Thanks for the replies
It's kind of reinforced what I was already thinking, that the main differences are window dressing, fancy remote & touch screen with no difference in functionality.
Will be going for the Pro version, then
:D
