• 30.03.2026, 06:44
peter003
missing tabs in aquasuite
Donnerstag, 30. Mai 2013, 10:52
I have the latest aquasuite software installed (as of May 2013) but am getting a reoccurring problem. For some unknown reason the 'user interface' and ' information pages' tabs on the main aquasuite window DISAPPEAR after a day or two. The software behaves well for a few days but then for no apparent reason these two tabs completely disappear. Am wondering if anyone else is experiencing the same or a similar problem and if there is a way to fix this bug without having to completely uninstall and then reinstall aquasuite. :?: :?: :?:
Grasshopper
Donnerstag, 30. Mai 2013, 12:50
I re installed.
export profiles and desktop display before you do
