• 27.03.2026, 06:11
galex
Poweradjust 2 USB, red light flashes.
Freitag, 7. Juni 2013, 09:35
My Poweradjust 2 USB flashes with red light. It always flashes independently of connections.
Steps of this issue.
1. Some time ago I have got red blinking after hardware manipulations and tunings.
2. I opened poweradjust page in aquasuite - it wasn't well detected and only Settings page there was with Firmware: 0.
3. I pressed button Update Firmware (it was enabled) -> some updating process passed.
4. After this the poweradjust always red flashes after startup.
Is it broken firmware issue? Is it possible to restore firmware?
Or may be I have broken the device with my hands accidentally. How can I get a detailed error cause of the device?
Thanks!
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »galex« (7. Juni 2013, 09:37)
Grasshopper
Samstag, 8. Juni 2013, 11:42
try flashing with aquasuite 4.72,
it appears from similar questions - all you can do is keep trying to flash it ( until you give up).
Common issue is people not power off before changing cables.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Grasshopper« (9. Juni 2013, 23:20)
galex
Sonntag, 9. Juni 2013, 15:14
It hasn't helped. :(
