• 10.01.2026, 13:51
Earthmonger
Will GTX 680 Acrylic Glass ed fit ref GTX 770?
Sonntag, 7. Juli 2013, 23:01
Since the GTX770 is just a rebadged 680, will a reference 680 block fit a reference 770 card?
http://shop.aquacomputer.de/product_info…roducts_id=3012
Jakusonfire
Montag, 8. Juli 2013, 11:57
A reference 770 uses a new PCB and there are specific water blocks for it.
There are however some 770's that use a 680 PCB and they will of course fit 680 water blocks
917K
Montag, 8. Juli 2013, 14:34
I've already asked, for a kryographis for the 770.
the only 770 that I've found with the 680 reference pcb is the zotac.
