• 03.04.2026, 07:41
SverreMunthe
Aquastream automatic frequency
Sonntag, 4. August 2013, 18:39
If I use automatic frequency one pump reaches 78Hz and the other 80Hz before they fall to around 40Hz. Is this normal behaviour? Is there any way to control the frequency against, say water temperature out of the radiators? I don't see any reason I should run them on max all the time.
Montag, 5. August 2013, 13:55
It is normal and has been already explained here.
