• 10.05.2026, 19:10
mblob
Connect 2 aquastreams to aquaero 5
Freitag, 6. September 2013, 01:10
hi,
Reading the manual i understand tht i connect my aquastream with the high aquabus connector. How am i supposed to connect the second one?
Thx
Namron
RE: Connect 2 aquastreams to aquaero 5
Freitag, 6. September 2013, 02:09
hi,
Thx
With something like THIS either 3 pin or 4 pin depending on what you want to use (but personally I'd get the four pin as that covers you if you decide to get other Aqua devices that may want a the 4 Pin aquabus cable connection)
N.
