• 01.04.2026, 07:19
capjlpicard
How to dim the LED ?
Dienstag, 12. November 2013, 10:13
I own an Aquaero 5 XT and I recently added the RGB
illumination led (PN# 34930).
I like it very much and it works fine but it is too
bright for my use. Is there a way to dim it ? I’m using Aquasuite 4.72.00
Thanks! :thumbup:
Paolo
Pilo
Dienstag, 12. November 2013, 15:11
The Aquasuite 4.72.00 isn't meant for the Aquaero 5 XT, it's among others an old version for the old Aquaero 4.
You need to download the Aquasuite 2013-3. You can deinstall the Aquasuite 4.72.00 then.
With the Aquasuite 2013 you gain full access to all functions of the Aquaero 5 XT.
Dienstag, 12. November 2013, 18:28
In AS2013
capjlpicard
Dienstag, 12. November 2013, 21:17
Sorry, my mistake.. I was actually running Aquasuite 2013-2 .. I did the update to 2013-3 and updated the firmware to 1033!
Thanks! :thumbsup:
capjlpicard
Dienstag, 12. November 2013, 21:19
In AS2013
EnigmaG, you opened my eyes..!! Thanks!!!! 8o :thumbsup: 8o
