• 17.02.2026, 14:31
dsadfsgffdg
pro vs xt
Dienstag, 10. Dezember 2013, 11:25
looking at the aquaero 6 pro and xt, what exactly are the differences between the two. I see one difference is the ir control, is that really useful? aslo xt says touch screen, i thought they were both touch screen? tx.
Namron
Dienstag, 10. Dezember 2013, 12:59
The XT is touch screen & comes with the remote control unit as standard........ The Pro Is NOT touch screen but button controlled & doesn't have the remote control unit supplied (it's an optional extra if you want/need it) like the XT variant.... Other than that there's nothing different about them, They both do exactly the same job in the same way :)
N.
