• 14.04.2026, 09:49
wa3pnt
Can Aquastream be controlled with a curve?
Dienstag, 17. Dezember 2013, 03:28
Getting ready for a new build that will have the Aquaero 6 and Aquastream Pump.
I've fired both up for a test, and do not see a way to control the Aquastream Pump Speed based on things like Water Temperature or CPU Temperature.
When creating a Control Curve in the Aquaero, the Aquastream is not listed as an available output device.
I also do not see that type of control option under the Aquastream in Aquasuite.
I love this pump, but unless I'm missing something I'm very disappointed in the lack of control capabilities.
RodeoGeorge
appel
Dienstag, 17. Dezember 2013, 17:14
I had the same thing.
seems to be impossible.
however its not really usefull.
pumping faster has not much impact on the temperature of the system.
Dienstag, 17. Dezember 2013, 18:52
No you can Not, the D5 Mps you can.
