• 24.03.2026, 02:56
Maximization
aquastream External Temp sensor connector question
Donnerstag, 26. Dezember 2013, 21:25
I came across a temp sensor but the connectors do not match the pin headers on the aquastream. What connector is needed? crimp pin and housing? I am very impressed with the aquastream so far, I guess i just to have everything plugged in. I have a koolance 10k temp sensor, but the connector is different. :crazy:
Freitag, 27. Dezember 2013, 01:37
10K Ohm is ok, 2 Pin the same as the power button.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »EnigmaG« (27. Dezember 2013, 01:40)
Okrim
Freitag, 27. Dezember 2013, 08:57
