• 23.01.2026, 09:59
Railgun
Feature request for Aquareo 6 as slave
Samstag, 18. Januar 2014, 19:50
So now that I'm running an Aquaero 6 as a slave, I noticed that the fan controllers cannot be controlled by PWM. So...if this is already in the works, then so be it, but if not, can you please enable the functionality to control the slave's outputs via PWM?
Also, from an addressing perspective, is it possible to enable the the rest of the unit beyond the fan controllers and four temp inputs?
Thanks in advance!
Railgun
Donnerstag, 6. Februar 2014, 20:32
Is this something that's possible?
Freitag, 7. Februar 2014, 07:27
That is not possible. The the additional features not available via aquabus. You can use the 2 aquaero parallel in one system with all features.
mandrix
Freitag, 7. Februar 2014, 17:23
I run 2x Aquaero 5 Pro units as separates....I don't really see an upside to running master/slave since you lose functionality....but hey, that's just me and I'm sure someone disagrees. :D
Railgun
Montag, 19. Dezember 2016, 08:41
So it's possible after all then?
